주요 콘텐츠로 건너뛰기
Acer Chromebook C720-2420 Motherboard Replacement
필요한 것
  1. Acer Chromebook C720-2420 Motherboard Replacement, Back Cover Replacement: 1 단계, 이미지 1/2 Acer Chromebook C720-2420 Motherboard Replacement, Back Cover Replacement: 1 단계, 이미지 2/2
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
  2. Acer Chromebook C720-2420 Motherboard Replacement: 2 단계, 이미지 1/1
    • Use the plastic opening tool to carefully remove the bottom.
  3. Acer Chromebook C720-2420 Motherboard Replacement, Battery: 3 단계, 이미지 1/2 Acer Chromebook C720-2420 Motherboard Replacement, Battery: 3 단계, 이미지 2/2
    • Remove the two 3.6 mm Phillips screws holding the battery in place.
  4. Acer Chromebook C720-2420 Motherboard Replacement: 4 단계, 이미지 1/2 Acer Chromebook C720-2420 Motherboard Replacement: 4 단계, 이미지 2/2
    • Disconnect the connector that attaches the battery to the Chromebook with a pair of pliers or tweezers.
    • Alternatively, you could use your hands, as it may be difficult to unhook the connector.
  5. Acer Chromebook C720-2420 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the battery.
  6. Acer Chromebook C720-2420 Motherboard Replacement, cooling fan / CPU heat sink assembly: 6 단계, 이미지 1/2 Acer Chromebook C720-2420 Motherboard Replacement, cooling fan / CPU heat sink assembly: 6 단계, 이미지 2/2
    • Remove the six 4.7 mm Phillips screws that secure the fan.
  7. Acer Chromebook C720-2420 Motherboard Replacement: 7 단계, 이미지 1/3 Acer Chromebook C720-2420 Motherboard Replacement: 7 단계, 이미지 2/3 Acer Chromebook C720-2420 Motherboard Replacement: 7 단계, 이미지 3/3
    • Disconnect these cables from the motherboard using the tweezers.
    • Alternatively, you may use your hands.
    • Pull out the fan.
  8. Acer Chromebook C720-2420 Motherboard Replacement, Memory: 8 단계, 이미지 1/2 Acer Chromebook C720-2420 Motherboard Replacement, Memory: 8 단계, 이미지 2/2
    • Remove the 3.6 mm Phillips screw that secures the SSD in place.
  9. Acer Chromebook C720-2420 Motherboard Replacement: 9 단계, 이미지 1/2 Acer Chromebook C720-2420 Motherboard Replacement: 9 단계, 이미지 2/2
    • Pull out the SSD.
  10. Acer Chromebook C720-2420 Motherboard Replacement, Motherboard: 10 단계, 이미지 1/1
    • Disconnect the speaker cable from the motherboard.
  11. Acer Chromebook C720-2420 Motherboard Replacement: 11 단계, 이미지 1/1
    • Disconnect the display cable from the motherboard.
  12. Acer Chromebook C720-2420 Motherboard Replacement: 12 단계, 이미지 1/1
    • Gently pull out the wire for the 2 PIC connectors.
  13. Acer Chromebook C720-2420 Motherboard Replacement: 13 단계, 이미지 1/1
    • Remove the two 3.7 mm Phillips screws that hold the motherboard in place.
  14. Acer Chromebook C720-2420 Motherboard Replacement: 14 단계, 이미지 1/1
    • Lift up the black tab on the ZIF connector to release the ribbon cable.
    • Carefully remove the ribbon cable.
  15. Acer Chromebook C720-2420 Motherboard Replacement: 15 단계, 이미지 1/1
    • Gently remove the ribbon cable
  16. Acer Chromebook C720-2420 Motherboard Replacement: 16 단계, 이미지 1/1
    • Remove the ribbon cable.
  17. Acer Chromebook C720-2420 Motherboard Replacement: 17 단계, 이미지 1/1
    • Lift up and remove the motherboard.
결론
Josue Pardo
회원 가입일: 02/12/18
187 평판
안내서 1개 작성함
USF Tampa, Team S15-G4, Boczar Spring 2018 USF Tampa, Team S15-G4, Boczar Spring 2018 회원
USFT-BOCZAR-S18S15G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 6
전체 시간: 313
