소개
This guide explains how to remove the battery. Before removing the battery, the front panel assembly will also need to be removed. Once the battery is reached, you will need to unplug some cables and unscrew some screws.
필요한 것
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
