소개
This guide will show you how to replace your Acer Chromebook C720-2827 display. You will need to follow some prerequisite guides including the back cover and battery replacement prior to beginning. Use this guide if your display is broken or has died.
부품
지정된 부품이 없습니다.
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
거의 끝나갑니다!
결론
