주요 콘텐츠로 건너뛰기
Acer Chromebook C720-2827 LED PCB Replacement
필요한 것
  1. Acer Chromebook C720-2827 LED PCB Replacement, Back Panel Assembly: 1 단계, 이미지 1/2 Acer Chromebook C720-2827 LED PCB Replacement, Back Panel Assembly: 1 단계, 이미지 2/2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 LED PCB Replacement: 2 단계, 이미지 1/2 Acer Chromebook C720-2827 LED PCB Replacement: 2 단계, 이미지 2/2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 LED PCB Replacement, Battery: 3 단계, 이미지 1/1
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 LED PCB Replacement: 4 단계, 이미지 1/2 Acer Chromebook C720-2827 LED PCB Replacement: 4 단계, 이미지 2/2
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 LED PCB Replacement: 5 단계, 이미지 1/1
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: 6 단계, 이미지 1/3 Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: 6 단계, 이미지 2/3 Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: 6 단계, 이미지 3/3
    • Use the Phillips #1 screwdriver to remove the two 3.1mm screws from the LED PCB.
    • Lift the LED PCB up with your fingers and flip it over revealing the ZIF connector.
    • The LED PCB is still tethered to the daughterboard via a ribbon cable so be sure not to yank it out or it could cause damage to the cable or its connectors.
  7. Acer Chromebook C720-2827 LED PCB Replacement: 7 단계, 이미지 1/3 Acer Chromebook C720-2827 LED PCB Replacement: 7 단계, 이미지 2/3 Acer Chromebook C720-2827 LED PCB Replacement: 7 단계, 이미지 3/3
    • Set the LED PCB down and use your spudger to flip up the white bar of the ZIF connector.
    • Pull the ribbon cable out with your fingers.
결론
Sarah Westberg
회원 가입일: 03/11/19
20,448 평판
안내서 70개 작성하였습니다
iFixit iFixit 회원
Community
136 회원들
안내서 15,166개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 214
