주요 콘텐츠로 건너뛰기
Acer Chromebook C720-2827 Motherboard Replacement
필요한 것
  1. Acer Chromebook C720-2827 Motherboard Replacement, Back Panel Assembly: 1 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement, Back Panel Assembly: 1 단계, 이미지 2개 중 2개
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 Motherboard Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 Motherboard Replacement, Solid State Drive: 6 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement, Solid State Drive: 6 단계, 이미지 2개 중 2개
    • Remove the single 3.0mm screw securing the solid state drive using a Phillips #1 screwdriver.
  7. Acer Chromebook C720-2827 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully pull out the solid state drive using two fingers.
  8. Acer Chromebook C720-2827 Motherboard Replacement, Speakers: 8 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement, Speakers: 8 단계, 이미지 2개 중 2개
    • Unplug the speaker wire from the motherboard.
  9. Acer Chromebook C720-2827 Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Carefully pull out the speakers from each side of the Chromebook.
  10. Acer Chromebook C720-2827 Motherboard Replacement, USB Port/SD Card Reader: 10 단계, 이미지 3개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement, USB Port/SD Card Reader: 10 단계, 이미지 3개 중 2개 Acer Chromebook C720-2827 Motherboard Replacement, USB Port/SD Card Reader: 10 단계, 이미지 3개 중 3개
    • Remove the three 6.0mm screws using the Phillips #1 screwdriver.
    • Remove the two 3.0mm screws using the Phillips #1 screwdriver.
  11. Acer Chromebook C720-2827 Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Position the spudger under the switch that connects the ribbon cable to the motherboard.
    • Flick the spudger up to flip the switch up.
  12. Acer Chromebook C720-2827 Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Pull the blue tab on the ribbon cable to remove it.
  13. Acer Chromebook C720-2827 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Grab the edges of each piece of circuitry that is included with the SD Card Reader and USB Port.
    • Pull each piece of circuitry out of the Chromebook and remove it from the device.
  14. Acer Chromebook C720-2827 Motherboard Replacement: 14 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Position the spudger under the switch.
  15. Acer Chromebook C720-2827 Motherboard Replacement: 15 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 15 단계, 이미지 2개 중 2개
    • Pull on the blue tab of the ribbon cable to remove the ribbon cable.
    • Repeat the previous step and this step with the other ribbon cable that is attached to the SD Card Reader/USB Port.
  16. Acer Chromebook C720-2827 Motherboard Replacement, Motherboard: 16 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement, Motherboard: 16 단계, 이미지 2개 중 2개
    • Using the Phillips #1 screwdriver, remove the four 3.0mm screws.
    • Loosen the six 3.0mm CPU screws using the Phillips #1 screwdriver.
    • The six 3.0mm CPU screws do not come out of the motherboard.
  17. Acer Chromebook C720-2827 Motherboard Replacement: 17 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 17 단계, 이미지 2개 중 2개
    • Grab the wire for the two pin connector.
    • Pull the wire to disconnect it from the motherboard.
  18. Acer Chromebook C720-2827 Motherboard Replacement: 18 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 18 단계, 이미지 2개 중 2개
    • Place the back of the spudger under the black wire that connects the wireless card to the motherboard.
    • Flick the spudger up to disconnect the cable from the motherboard.
  19. Acer Chromebook C720-2827 Motherboard Replacement: 19 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 19 단계, 이미지 2개 중 2개
    • Place the back of the spudger under the white coaxial antenna wire that connects the wireless card to the motherboard.
  20. Acer Chromebook C720-2827 Motherboard Replacement: 20 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 20 단계, 이미지 2개 중 2개
    • Take both wires and unravel them from the CPU fan.
  21. Acer Chromebook C720-2827 Motherboard Replacement: 21 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 21 단계, 이미지 2개 중 2개
    • Firmly grasp the red, yellow, and white cords with two fingers.
    • Pull the cords to unplug it.
  22. Acer Chromebook C720-2827 Motherboard Replacement: 22 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 22 단계, 이미지 2개 중 2개
    • Position the spudger under the switch of the big ribbon cable.
  23. Acer Chromebook C720-2827 Motherboard Replacement: 23 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 23 단계, 이미지 2개 중 2개
    • Grab the blue tab of the ribbon cable.
    • Pull on the blue tab to disconnect the ribbon cable.
  24. Acer Chromebook C720-2827 Motherboard Replacement: 24 단계, 이미지 3개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 24 단계, 이미지 3개 중 2개 Acer Chromebook C720-2827 Motherboard Replacement: 24 단계, 이미지 3개 중 3개
    • Grab the red and black cable near the display cables, this is the cable to the other two pin connector.
    • Pull on the wire to disconnect it from the motherboard.
    • Flip the wire and the connector up to move it out of the way.
  25. Acer Chromebook C720-2827 Motherboard Replacement: 25 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 25 단계, 이미지 2개 중 2개
    • Position the spudger under the switch for the smaller ribbon cable.
    • Flick the spudger up to flip the smaller switch up.
  26. Acer Chromebook C720-2827 Motherboard Replacement: 26 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 26 단계, 이미지 2개 중 2개
    • Grab the blue tab on the ribbon cable.
    • Pull on the tab to disconnect the ribbon cable from the motherboard.
  27. Acer Chromebook C720-2827 Motherboard Replacement: 27 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 27 단계, 이미지 2개 중 2개
    • Position the back of the spudger at the edge of the tape that holds the display cable in.
    • Peel the tape back so it is out of the way.
  28. Acer Chromebook C720-2827 Motherboard Replacement: 28 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 28 단계, 이미지 2개 중 2개
    • Position the back of the spudger on the display cable.
    • Push the display cable out using the back of the spudger.
  29. Acer Chromebook C720-2827 Motherboard Replacement: 29 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Motherboard Replacement: 29 단계, 이미지 2개 중 2개
    • Lift up the CPU fan to ensure that no wires are tangled. If the black and white wires are tangles please repeat step 5.
    • Lift up the other end of the motherboard to completely remove the motherboard.
결론
작성자
5다른 기여자 명과 함께
Jason Bechtold
회원 가입일: 10/19/17
611 평판
안내서 5개를 작성함
UMass Dartmouth, Team S4-G7, Julie Fall 2017 UMass Dartmouth, Team S4-G7, Julie Fall 2017 회원
UMASSD-JULIE-F17S4G7
1 회원
안내서 7개를 작성함
1가이드 댓글
Plz mujhy mother bother chaiya Chromebook ma ya Merry num 03487834288
Sheryer Shakeel ahmed - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 18
전체 시간: 511
