주요 콘텐츠로 건너뛰기
Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement
필요한 것
  1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Back Panel Assembly: 1 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Back Panel Assembly: 1 단계, 이미지 2개 중 2개
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 2 단계, 이미지 2개 중 2개
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 5 단계, 이미지 1개 중 1개
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Speakers: 6 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Speakers: 6 단계, 이미지 2개 중 2개
    • Unplug the speaker wire from the motherboard.
  7. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully pull out the speakers from each side of the Chromebook.
  8. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: 8 단계, 이미지 3개 중 1개 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: 8 단계, 이미지 3개 중 2개 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: 8 단계, 이미지 3개 중 3개
    • Remove the three 6.0mm screws using the Phillips #1 screwdriver.
    • Remove the two 3.0mm screws using the Phillips #1 screwdriver.
  9. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 9 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 9 단계, 이미지 2개 중 2개
    • Position the spudger under the switch that connects the ribbon cable to the motherboard.
    • Flick the spudger up to flip the switch up.
  10. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 10 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 10 단계, 이미지 2개 중 2개
    • Pull the blue tab on the ribbon cable to remove it.
  11. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 11 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 11 단계, 이미지 2개 중 2개
    • Grab the edges of each piece of circuitry that is included with the SD Card Reader and USB Port.
    • Pull each piece of circuitry out of the Chromebook and remove it from the device.
  12. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 12 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 12 단계, 이미지 2개 중 2개
    • Position the spudger under the switch.
  13. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 13 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: 13 단계, 이미지 2개 중 2개
    • Pull on the blue tab of the ribbon cable to remove the ribbon cable.
    • Repeat the previous step and this step with the other ribbon cable that is attached to the SD Card Reader/USB Port.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jason Bechtold
회원 가입일: 10/19/17
611 평판
안내서 5개를 작성함
UMass Dartmouth, Team S4-G7, Julie Fall 2017 UMass Dartmouth, Team S4-G7, Julie Fall 2017 회원
UMASSD-JULIE-F17S4G7
1 회원
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 4
전체 시간: 342
