소개
This guide will mainly focus on removing the speakers. First, you will need to remove the back panel. Next, you will need to remove the battery.
필요한 것
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
거의 끝나갑니다!
결론
