주요 콘텐츠로 건너뛰기
Acer Chromebook C720-2827 Speakers Replacement
필요한 것
  1. Acer Chromebook C720-2827 Speakers Replacement, Back Panel Assembly: 1 단계, 이미지 1/2 Acer Chromebook C720-2827 Speakers Replacement, Back Panel Assembly: 1 단계, 이미지 2/2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 Speakers Replacement: 2 단계, 이미지 1/2 Acer Chromebook C720-2827 Speakers Replacement: 2 단계, 이미지 2/2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 Speakers Replacement, Battery: 3 단계, 이미지 1/1
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 Speakers Replacement: 4 단계, 이미지 1/2 Acer Chromebook C720-2827 Speakers Replacement: 4 단계, 이미지 2/2
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 Speakers Replacement: 5 단계, 이미지 1/1
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 Speakers Replacement, Speakers: 6 단계, 이미지 1/2 Acer Chromebook C720-2827 Speakers Replacement, Speakers: 6 단계, 이미지 2/2
    • Unplug the speaker wire from the motherboard.
  7. Acer Chromebook C720-2827 Speakers Replacement: 7 단계, 이미지 1/2 Acer Chromebook C720-2827 Speakers Replacement: 7 단계, 이미지 2/2
    • Carefully pull out the speakers from each side of the Chromebook.
결론
Kennedy Morales
회원 가입일: 10/20/17
655 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team S2-G3, Peak Fall 2018 UMass Dartmouth, Team S2-G3, Peak Fall 2018 회원
UMASSD-PEAK-F18S2G3
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 307
