주요 콘텐츠로 건너뛰기
Acer Chromebook C720-2827 Trackpad Replacement
필요한 것
  1. Acer Chromebook C720-2827 Trackpad Replacement, Back Panel Assembly: 1 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Trackpad Replacement, Back Panel Assembly: 1 단계, 이미지 2개 중 2개
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 Trackpad Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Trackpad Replacement: 2 단계, 이미지 2개 중 2개
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 Trackpad Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 Trackpad Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Trackpad Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 Trackpad Replacement: 5 단계, 이미지 1개 중 1개
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 Trackpad Replacement, Trackpad: 6 단계, 이미지 3개 중 1개 Acer Chromebook C720-2827 Trackpad Replacement, Trackpad: 6 단계, 이미지 3개 중 2개 Acer Chromebook C720-2827 Trackpad Replacement, Trackpad: 6 단계, 이미지 3개 중 3개
    • Using a spudger, pry up the locking bar of the ZIF connector on the trackpad and remove the ribbon cable.
  7. Acer Chromebook C720-2827 Trackpad Replacement: 7 단계, 이미지 3개 중 1개 Acer Chromebook C720-2827 Trackpad Replacement: 7 단계, 이미지 3개 중 2개 Acer Chromebook C720-2827 Trackpad Replacement: 7 단계, 이미지 3개 중 3개
    • Peel off the clear plastic covering the screws.
    • Remove the five grey 2.5 mm screws securing the trackpad with a Phillips #1 screwdriver.
    • Remove another four silver 2.9mm Phillips #1 screws from the silver bracket atop the trackpad with your driver.
  8. Acer Chromebook C720-2827 Trackpad Replacement: 8 단계, 이미지 2개 중 1개 Acer Chromebook C720-2827 Trackpad Replacement: 8 단계, 이미지 2개 중 2개
    • Lift up the silver bracket.
    • Remove the trackpad by lifting it up from the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Austin Blakely
회원 가입일: 03/11/19
21,298 평판
안내서 53개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,536개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 271
