이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
Using a spudger, pry up the locking bar of the ZIF connector on the trackpad and remove the ribbon cable.
Peel off the clear plastic covering the screws.
Remove the five grey 2.5 mm screws securing the trackpad with a Phillips #1 screwdriver.
Remove another four silver 2.9mm Phillips #1 screws from the silver bracket atop the trackpad with your driver.
Lift up the silver bracket.
Remove the trackpad by lifting it up from the case.
다른 한 분이 해당 안내서를 완성하였습니다.
