주요 콘텐츠로 건너뛰기
Acer Chromebook C720-2844 Touch Pad Replacement
필요한 것
  1. Acer Chromebook C720-2844 Touch Pad Replacement, Battery: 1 단계, 이미지 1/3 Acer Chromebook C720-2844 Touch Pad Replacement, Battery: 1 단계, 이미지 2/3 Acer Chromebook C720-2844 Touch Pad Replacement, Battery: 1 단계, 이미지 3/3
    • Flip to the back cover of the laptop.
    • Remove the 1 cm Phillips #00 screws on the back cover.
    • Use pry tools to remove the back cover.
  2. Acer Chromebook C720-2844 Touch Pad Replacement: 2 단계, 이미지 1/1
    • Take out your Phillips #00 screwdriver.
    • Remove the 1 cm screws of the battery. There are two of screws, one is on the left of the battery and the other is on the right. (circled in red).
  3. Acer Chromebook C720-2844 Touch Pad Replacement: 3 단계, 이미지 1/2 Acer Chromebook C720-2844 Touch Pad Replacement: 3 단계, 이미지 2/2
    • Unplug the battery from the motherboard by pulling the bundled cable connector free.
    • Lift the top part of battery.
    • Slide the battery forward to remove it completely from the motherboard.
  4. Acer Chromebook C720-2844 Touch Pad Replacement, Touch Pad: 4 단계, 이미지 1/1
    • Lift white tab holding connector.
    • Pull from blue tab to disconnect.
  5. Acer Chromebook C720-2844 Touch Pad Replacement: 5 단계, 이미지 1/1
    • Unscrew and remove the four 1 cm Phillips #00 screws under transparent cover.
  6. Acer Chromebook C720-2844 Touch Pad Replacement: 6 단계, 이미지 1/2 Acer Chromebook C720-2844 Touch Pad Replacement: 6 단계, 이미지 2/2
    • Unscrew and remove the two 1 cm Phillips #00 screws that secure the touchpad bracket.
    • Lift bracket to remove from touchpad.
  7. Acer Chromebook C720-2844 Touch Pad Replacement: 7 단계, 이미지 1/1
    • Remove the tape securing the touchpad to the shell.
  8. Acer Chromebook C720-2844 Touch Pad Replacement: 8 단계, 이미지 1/1
    • Lift and remove touchpad.
결론
Christian Madrigal
회원 가입일: 02/10/22
229 평판
안내서 2개 작성하였습니다
Gateway, Team 1-2, Pee Spring 2022 Gateway, Team 1-2, Pee Spring 2022 회원
GCC-PEE-S22S1G2
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 8
전체 시간: 127
