주요 콘텐츠로 건너뛰기
Acer Chromebook C720-2848 Screen Replacement
필요한 것
  1. Acer Chromebook C720-2848  Screen Replacement, Screen: 1 단계, 이미지 2개 중 1개 Acer Chromebook C720-2848  Screen Replacement, Screen: 1 단계, 이미지 2개 중 2개
    • Insert a metal spudger around the inner side of the screens plastic perimeter.
    • Move along the perimeter while leveraging to pop the faceplate out like so.
  2. Acer Chromebook C720-2848  Screen Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook C720-2848  Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the faceplate's bottom hinges that connect to the body of the device with the metal spudger. This will free the plastic perimeter, which may now be removed.
  3. Acer Chromebook C720-2848  Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the 6 screws in these circled locations.
  4. Acer Chromebook C720-2848  Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Reposition so the screen will lay flat on the keyboard of the laptop.
  5. Acer Chromebook C720-2848  Screen Replacement: 5 단계, 이미지 2개 중 1개 Acer Chromebook C720-2848  Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Locate the bar code adhesion strip at the base of the screen, and then peel it back carefully. Once peeled back the plug-in will come free.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Cory Provost
회원 가입일: 09/27/17
212 평판
안내서 1개를 작성함
USF Tampa, Team S9-G3, Remmell Fall 2017 USF Tampa, Team S9-G3, Remmell Fall 2017 회원
USFT-REMMELL-F17S9G3
4 회원들
안내서 9개를 작성함
댓글 한 개
In step 2, "the faceplate's bottom hinges" are plastic hinge covers that are (or, at least, were) part of the bezel. You may be able to take the bezel off while they're still attached, or you may have to break the flexing points so that they come off separately. Either way, it doesn't seem to cause a problem.
Thanks, Cory.
Lance ==)--------------
Lance - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 1,851
