주요 콘텐츠로 건너뛰기
Acer Chromebook C720-2848 Trackpad Replacement
필요한 것
  1. Acer Chromebook C720-2848 Trackpad Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Acer Chromebook C720-2848 Trackpad Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Use a Phillips head screw driver to remove the 13 screws in these locations.
  2. Acer Chromebook C720-2848 Trackpad Replacement: 2 단계, 이미지 3개 중 1개 Acer Chromebook C720-2848 Trackpad Replacement: 2 단계, 이미지 3개 중 2개 Acer Chromebook C720-2848 Trackpad Replacement: 2 단계, 이미지 3개 중 3개
    • Use a plastic spudger to pry up the bottom cover and remove it.
    • Be sure to pry along other edges if necessary to avoid damaging the back cover.
  3. Acer Chromebook C720-2848 Trackpad Replacement, Battery: 3 단계, 이미지 3개 중 1개 Acer Chromebook C720-2848 Trackpad Replacement, Battery: 3 단계, 이미지 3개 중 2개 Acer Chromebook C720-2848 Trackpad Replacement, Battery: 3 단계, 이미지 3개 중 3개
    • Unscrew the 2 battery screws.
    • Make sure you keep these screws separate from the back cover screws; they are different!
  4. Acer Chromebook C720-2848 Trackpad Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook C720-2848 Trackpad Replacement: 4 단계, 이미지 2개 중 2개
    • Use two fingers to unplug the battery-to-motherboard connection.
  5. Acer Chromebook C720-2848 Trackpad Replacement: 5 단계, 이미지 1개 중 1개
    • Take out battery by lifting it up in the manner pictured.
  6. Acer Chromebook C720-2848 Trackpad Replacement, Trackpad: 6 단계, 이미지 2개 중 1개 Acer Chromebook C720-2848 Trackpad Replacement, Trackpad: 6 단계, 이미지 2개 중 2개
    • Remove 9 trackpad screws. They will be of two different varieties.
    • Make sure to keep these screw separate from those in the previous steps.
    • On the back of the trackpad, there is a plastic film that will cover some of the screws. Simply pull it back (do not pull if off) to remove the screws.
  7. Acer Chromebook C720-2848 Trackpad Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook C720-2848 Trackpad Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the trackpad ribbon cable.
    • To do this, lift the small black component; it is hinged to the white component.
    • Then simply pull the ribbon cable out of the connector.
  8. Acer Chromebook C720-2848 Trackpad Replacement: 8 단계, 이미지 3개 중 1개 Acer Chromebook C720-2848 Trackpad Replacement: 8 단계, 이미지 3개 중 2개 Acer Chromebook C720-2848 Trackpad Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the small metal frame by simply lifting it out.
    • Carefully peel up the tape holding the trackpad in place.
    • Remove the trackpad from the computer frame.
    • Make sure to watch for any wires or other components and ensure that they are out of the way when removing the trackpad.
결론
작성자
1다른 기여자 명과 함께
Richard Schmidt
회원 가입일: 03/19/18
337 평판
안내서 2개를 작성함
Baylor, Team S3-G1, Williams Spring 2018 Baylor, Team S3-G1, Williams Spring 2018 회원
BU-WILLIAMS-S18S3G1
4 회원들
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 641
