주요 콘텐츠로 건너뛰기
Acer Chromebook C731-C8VE I/O Board Replacement
필요한 것
  1. Acer Chromebook C731-C8VE I/O Board Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place the Chromebook face down.
  2. Acer Chromebook C731-C8VE I/O Board Replacement: 2 단계, 이미지 1개 중 1개
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2 mm screws have washers and will be located on the left and right of the device.
    • The 2 mm screws marked orange do not have washers attached and must be placed in these specific areas.
  3. Acer Chromebook C731-C8VE I/O Board Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook C731-C8VE I/O Board Replacement: 3 단계, 이미지 2개 중 2개
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE I/O Board Replacement: 4 단계, 이미지 3개 중 1개 Acer Chromebook C731-C8VE I/O Board Replacement: 4 단계, 이미지 3개 중 2개 Acer Chromebook C731-C8VE I/O Board Replacement: 4 단계, 이미지 3개 중 3개
    • Detach the wires connecting the keyboard and the touchpad to the motherboard by lifting the black connectors up.
  5. Acer Chromebook C731-C8VE I/O Board Replacement: 5 단계, 이미지 3개 중 1개 Acer Chromebook C731-C8VE I/O Board Replacement: 5 단계, 이미지 3개 중 2개 Acer Chromebook C731-C8VE I/O Board Replacement: 5 단계, 이미지 3개 중 3개
    • Use the JIS #00 screwdriver to take out the 1mm screw that connects the battery to the base.
    • Detach the battery from the motherboard by lifting it up gently to avoid any damage to the motherboard.
  6. Acer Chromebook C731-C8VE I/O Board Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the battery from the base of the device.
    • Do this step slowly to ensure that you do not damage the battery or the motherboard.
  7. Acer Chromebook C731-C8VE I/O Board Replacement, I/O Board: 7 단계, 이미지 2개 중 1개 Acer Chromebook C731-C8VE I/O Board Replacement, I/O Board: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Push up the latch connected to the ribbon cable on the I/O board with a nylon spudger.
    • Gently remove the cable from the I/O board with tweezers.
    • It is not required to remove the ribbon cable from the motherboard, only from the I/O board.
    • Remove the 5 mm screw from the I/O board using a JIS #00 screwdriver.
  8. Acer Chromebook C731-C8VE I/O Board Replacement: 8 단계, 이미지 2개 중 1개 Acer Chromebook C731-C8VE I/O Board Replacement: 8 단계, 이미지 2개 중 2개
    • Gently leverage the I/O board using the spudger until you can nudge it from underneath.
    • Carefully grab the I/O board with your fingers and remove it from the device.
결론
작성자
3다른 기여자 명과 함께
Ethan Johnson
회원 가입일: 02/21/23
199 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 217
