주요 콘텐츠로 건너뛰기
Acer Chromebook C731-C8VE Wi-Fi Card Replacement
필요한 것
  1. Acer Chromebook C731-C8VE Wi-Fi Card Replacement, Wi-Fi Card: 1 단계, 이미지 1개 중 1개
    • Place Chromebook face down.
  2. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: 2 단계, 이미지 2개 중 2개
    • Make sure to completely turn off the device before beginning this step.
    • Use a JIS #00 screwdriver to remove the 11 screws on the underside of the laptop.
    • These 2mm screws have washers and must be placed in these specific areas.
    • The 2mm screws marked orange do not have washers and will be placed on the left and right of the device.
  3. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: 3 단계, 이미지 3개 중 1개 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: 3 단계, 이미지 3개 중 2개 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: 3 단계, 이미지 3개 중 3개
    • Use the iFixit opening tool to remove the keyboard from the device by prying it loose from the base.
  4. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: 4 단계, 이미지 3개 중 1개 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: 4 단계, 이미지 3개 중 2개 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: 4 단계, 이미지 3개 중 3개
    • Detach the two wires that connect the Wi-Fi card to the screen.
    • The white wire will attach to the top and the black wire to the bottom.
  5. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: 5 단계, 이미지 3개 중 1개 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: 5 단계, 이미지 3개 중 2개 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: 5 단계, 이미지 3개 중 3개
    • Use the JIS #00 screwdriver to unscrew the single 1mm screw connecting the Wi-Fi card to the base.
    • Once the screw is removed, the Wi-Fi card will pop up.
  6. Acer Chromebook C731-C8VE Wi-Fi Card Replacement: 6 단계, 이미지 3개 중 1개 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: 6 단계, 이미지 3개 중 2개 Acer Chromebook C731-C8VE Wi-Fi Card Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the Wi-Fi card from the motherboard.
결론
작성자
2다른 기여자 명과 함께
Justin Menninger
회원 가입일: 03/21/22
400 평판
안내서 3개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 4
전체 시간: 225
