소개
The battery replacement for the Acer Chromebook C740 requires removing several screws, prying the pack panel off, and unplugging the battery. This disassembly is required for several other replacement guides.
필요한 것
Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
거의 끝나갑니다!
결론
다른 7명이 해당 안내서를 완성하였습니다.
