주요 콘텐츠로 건너뛰기
Acer Chromebook C740 LCD Screen Replacement
필요한 것
  1. Acer Chromebook C740 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/1
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 LCD Screen Replacement: 2 단계, 이미지 1/2 Acer Chromebook C740 LCD Screen Replacement: 2 단계, 이미지 2/2
    • With the Chromebook open and face up, pry the black screen frame with your fingers.
    • Move slowly around the display to evenly remove it.
    • Clicking sounds indicate the panel is seperating from the overall display.
  3. Acer Chromebook C740 LCD Screen Replacement: 3 단계, 이미지 1/1
    • Once the frame is separated from the display, angle the display assembly back .
    • Lift up the portions of the frame covering the front two hinges with the spudger.
  4. Acer Chromebook C740 LCD Screen Replacement: 4 단계, 이미지 1/1
    • Remove the frame from the screen assembly by pulling the frame towards you.
    • Some adjustment of the display assembly may be needed so that the frame is not stuck near the hinges.
  5. Acer Chromebook C740 LCD Screen Replacement: 5 단계, 이미지 1/2 Acer Chromebook C740 LCD Screen Replacement: 5 단계, 이미지 2/2
    • Remove the six 3.35mm screws with a Phillips #0 Screwdriver.
  6. Acer Chromebook C740 LCD Screen Replacement: 6 단계, 이미지 1/3 Acer Chromebook C740 LCD Screen Replacement: 6 단계, 이미지 2/3 Acer Chromebook C740 LCD Screen Replacement: 6 단계, 이미지 3/3
    • Place the LCD screen face down on the keyboard.
    • Remove the tape holding the black connector in place.
    • Unplug the connector with your hands.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Grace Bassett
회원 가입일: 04/26/17
217 평판
안내서 1개 작성함
Cal Poly, Team S22-G2, Livingston Spring 2017 Cal Poly, Team S22-G2, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G2
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
You actually don’t need to unscrew the middle screws, and you don’t need to buy a new bezel.
Keith Hudson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 26
전체 시간: 3,321
