이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
With the Chromebook open and face up, pry the black screen frame with your fingers.
Move slowly around the display to evenly remove it.
Once the frame is separated from the display, angle the display assembly back .
Lift up the portions of the frame covering the front two hinges with the spudger.
Remove the frame from the screen assembly by pulling the frame towards you.
Place the LCD screen face down on the keyboard.
Remove the tape holding the black connector in place.
Unplug the connector with your hands.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 한 개
You actually don’t need to unscrew the middle screws, and you don’t need to buy a new bezel.
