주요 콘텐츠로 건너뛰기
Acer Chromebook C740 Trackpad Replacement
필요한 것
  1. Acer Chromebook C740 Trackpad Replacement, Back Panel: 1 단계, 이미지 1/1
    • Power down the Chromebook and disconnect the power adapter.
  2. Acer Chromebook C740 Trackpad Replacement: 2 단계, 이미지 1/2 Acer Chromebook C740 Trackpad Replacement: 2 단계, 이미지 2/2
    • Place the chromebook bottom side up on a flat surface.
    • Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
  3. Acer Chromebook C740 Trackpad Replacement: 3 단계, 이미지 1/3 Acer Chromebook C740 Trackpad Replacement: 3 단계, 이미지 2/3 Acer Chromebook C740 Trackpad Replacement: 3 단계, 이미지 3/3
    • Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
    • Applying pressure may be necessary. A click indicates the panel is ready to come off.
  4. Acer Chromebook C740 Trackpad Replacement, Battery: 4 단계, 이미지 1/3 Acer Chromebook C740 Trackpad Replacement, Battery: 4 단계, 이미지 2/3 Acer Chromebook C740 Trackpad Replacement, Battery: 4 단계, 이미지 3/3
    • Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
    • The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience.
  5. Acer Chromebook C740 Trackpad Replacement: 5 단계, 이미지 1/2 Acer Chromebook C740 Trackpad Replacement: 5 단계, 이미지 2/2
    • Remove the the two 3.7 mm screws with a Phillips #0 screwdriver.
  6. Acer Chromebook C740 Trackpad Replacement: 6 단계, 이미지 1/1
    • Lift the battery from the frame.
  7. Acer Chromebook C740 Trackpad Replacement, Trackpad: 7 단계, 이미지 1/3 Acer Chromebook C740 Trackpad Replacement, Trackpad: 7 단계, 이미지 2/3 Acer Chromebook C740 Trackpad Replacement, Trackpad: 7 단계, 이미지 3/3
    • Pull the black wire out from under the the black center clips and up from the gray outer clips with a spudger.
  8. Acer Chromebook C740 Trackpad Replacement: 8 단계, 이미지 1/2 Acer Chromebook C740 Trackpad Replacement: 8 단계, 이미지 2/2
    • Use a spudger to lift the black clip on the small purple ribbon cable connector to the left of the touchpad.
    • Pull the ribbon cable out from the connector.
  9. Acer Chromebook C740 Trackpad Replacement: 9 단계, 이미지 1/2 Acer Chromebook C740 Trackpad Replacement: 9 단계, 이미지 2/2
    • Remove the five 2.5 mm screws with a Phillips #0 screwdriver.
  10. Acer Chromebook C740 Trackpad Replacement: 10 단계, 이미지 1/2 Acer Chromebook C740 Trackpad Replacement: 10 단계, 이미지 2/2
    • Remove the four 2.8 mm screws with a Phillips #00 screwdriver.
  11. Acer Chromebook C740 Trackpad Replacement: 11 단계, 이미지 1/2 Acer Chromebook C740 Trackpad Replacement: 11 단계, 이미지 2/2
    • Wiggle off the silver bracket with your fingers.
  12. Acer Chromebook C740 Trackpad Replacement: 12 단계, 이미지 1/2 Acer Chromebook C740 Trackpad Replacement: 12 단계, 이미지 2/2
    • Remove the black tape on the left side of the touchpad.
  13. Acer Chromebook C740 Trackpad Replacement: 13 단계, 이미지 1/2 Acer Chromebook C740 Trackpad Replacement: 13 단계, 이미지 2/2
    • Lift off the black plastic cover with the plastic opening tool.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Flor De La Rosa
회원 가입일: 04/25/17
875 평판
안내서 4개 작성하였습니다
Cal Poly, Team S22-G2, Livingston Spring 2017 Cal Poly, Team S22-G2, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 21
전체 시간: 2,552
