주요 콘텐츠로 건너뛰기
Acer Chromebook C740-C4PE Heatsink Replacement
필요한 것
  1. Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: 1 단계, 이미지 3개 중 1개 Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: 1 단계, 이미지 3개 중 2개 Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: 1 단계, 이미지 3개 중 3개
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the thirteen 10mm screws on the back of the device using a Phillips #0 screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Heatsink Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook C740-C4PE Heatsink Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the four 5mm screws on the heatsink using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Heatsink Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook C740-C4PE Heatsink Replacement: 3 단계, 이미지 2개 중 2개
    • Loosen the two Phillips-head screws on the fan attached to the heatsink.
  4. Acer Chromebook C740-C4PE Heatsink Replacement: 4 단계, 이미지 1개 중 1개
    • Detach the two antennae cables from the WiFi card by gently pulling on them.
  5. Acer Chromebook C740-C4PE Heatsink Replacement: 5 단계, 이미지 1개 중 1개
    • Gently pull the fan cable out of the motherboard.
    • Pulling too hard may break the wires or the connector itself.
  6. Acer Chromebook C740-C4PE Heatsink Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the cable routed through the fan.
    • Do not completely remove the cables as they are attached to the motherboard. Once they are no longer routed in the fan, leave them as they are.
  7. Acer Chromebook C740-C4PE Heatsink Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the heatsink from the motherboard.
    • Before changing the heatsink/fan, you must clean off the thermal paste from the CPU and apply new thermal paste.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Dylan Tocci
회원 가입일: 10/17/17
237 평판
안내서 2개를 작성함
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 UMass Dartmouth, Team S6-G4, Rockett Fall 2017 회원
UMASSD-ROCKETT-F17S6G4
3 회원들
안내서 12개를 작성함
댓글 한 개
What type of thermal paste is best used?
Tracey Arria - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 13
전체 시간: 394
