주요 콘텐츠로 건너뛰기
Acer Chromebook C740-C4PE Motherboard Replacement
필요한 것
  1. Acer Chromebook C740-C4PE Motherboard Replacement, Heatsink: 1 단계, 이미지 3개 중 1개 Acer Chromebook C740-C4PE Motherboard Replacement, Heatsink: 1 단계, 이미지 3개 중 2개 Acer Chromebook C740-C4PE Motherboard Replacement, Heatsink: 1 단계, 이미지 3개 중 3개
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the thirteen 10mm screws on the back of the device using a Phillips #0 screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook C740-C4PE Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the four 5mm screws on the heatsink using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook C740-C4PE Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Loosen the two Phillips-head screws on the fan attached to the heatsink.
  4. Acer Chromebook C740-C4PE Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Detach the two antennae cables from the WiFi card by gently pulling on them.
  5. Acer Chromebook C740-C4PE Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Gently pull the fan cable out of the motherboard.
    • Pulling too hard may break the wires or the connector itself.
  6. Acer Chromebook C740-C4PE Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the cable routed through the fan.
    • Do not completely remove the cables as they are attached to the motherboard. Once they are no longer routed in the fan, leave them as they are.
  7. Acer Chromebook C740-C4PE Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the heatsink from the motherboard.
    • Before changing the heatsink/fan, you must clean off the thermal paste from the CPU and apply new thermal paste.
  8. Acer Chromebook C740-C4PE Motherboard Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
    • Remove the 5mm screw holding the SSD in place using the Phillips #0 screwdriver.
  9. Acer Chromebook C740-C4PE Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Acer Chromebook C740-C4PE Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Slide the SSD out of its slot in the motherboard.
  10. Acer Chromebook C740-C4PE Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the two 5mm screws holding the battery in place using a Phillips #0 screwdriver.
  11. Acer Chromebook C740-C4PE Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the battery cable attached to the motherboard.
  12. Acer Chromebook C740-C4PE Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Pull out the battery.
  13. Acer Chromebook C740-C4PE Motherboard Replacement: 13 단계, 이미지 2개 중 1개 Acer Chromebook C740-C4PE Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the speaker cable from the motherboard.
  14. Acer Chromebook C740-C4PE Motherboard Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the touchpad cable from the zero insertion force connector on the motherboard.
    • Be sure to push up the plastic tab that holds the cable in place before removing it. Failure to do this could result in snapping the cable.
  15. Acer Chromebook C740-C4PE Motherboard Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the keyboard cable from the zero insertion force connector on the motherboard.
    • Be sure to push open the plastic tab that holds the cable in place before removing the cable.
  16. Acer Chromebook C740-C4PE Motherboard Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the mother-to-daughter cable from the zero insertion force connector on the motherboard.
  17. Acer Chromebook C740-C4PE Motherboard Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the LCD cable from the motherboard.
  18. Acer Chromebook C740-C4PE Motherboard Replacement: 18 단계, 이미지 1개 중 1개
    • Remove the two 5mm screws holding the motherboard in place using a Phillips #0 screwdriver.
  19. Acer Chromebook C740-C4PE Motherboard Replacement: 19 단계, 이미지 1개 중 1개
    • Remove the motherboard.
    • Make sure your body does not have static electricity when handling the new motherboard as you could shock it. This could potentially break the new motherboard. Touch your finger on to something metal before handling the new motherboard.
결론
작성자
1다른 기여자 명과 함께
Dylan Tocci
회원 가입일: 10/17/17
237 평판
안내서 2개를 작성함
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 UMass Dartmouth, Team S6-G4, Rockett Fall 2017 회원
UMASSD-ROCKETT-F17S6G4
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 798
