주요 콘텐츠로 건너뛰기
Acer Chromebook C740-C4PE Touchpad Replacement
필요한 것
  1. Acer Chromebook C740-C4PE Touchpad Replacement, Battery: 1 단계, 이미지 3개 중 1개 Acer Chromebook C740-C4PE Touchpad Replacement, Battery: 1 단계, 이미지 3개 중 2개 Acer Chromebook C740-C4PE Touchpad Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Make sure the laptop is turned off and unplugged before starting.
    • Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
    • Using the spudger or other prying tool, gently pry the back off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Touchpad Replacement: 2 단계, 이미지 1개 중 1개
    • Unscrew the two 5mm battery screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Touchpad Replacement: 3 단계, 이미지 1개 중 1개
    • Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
    • Be sure the battery is away from the clips before pulling away so as not to break the clips.
  4. Acer Chromebook C740-C4PE Touchpad Replacement: 4 단계, 이미지 3개 중 1개 Acer Chromebook C740-C4PE Touchpad Replacement: 4 단계, 이미지 3개 중 2개 Acer Chromebook C740-C4PE Touchpad Replacement: 4 단계, 이미지 3개 중 3개
    • Detach the connecting cable from the motherboard by pulling away.
    • Remove the battery from the device.
  5. Acer Chromebook C740-C4PE Touchpad Replacement, Touchpad: 5 단계, 이미지 2개 중 1개 Acer Chromebook C740-C4PE Touchpad Replacement, Touchpad: 5 단계, 이미지 2개 중 2개
    • Unscrew the two screws on the silver restraint with the Phillips #0 screwdriver.
    • Lift the silver restraint from the device.
  6. Acer Chromebook C740-C4PE Touchpad Replacement: 6 단계, 이미지 1개 중 1개
    • Unscrew the five screws on the touchpad.
    • You will need to move aside the plastic covering that is above each screw.
  7. Acer Chromebook C740-C4PE Touchpad Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook C740-C4PE Touchpad Replacement: 7 단계, 이미지 2개 중 2개
    • Using a spudger, lift the black electrical tape to the left of the touchpad.
    • Remove the black wire running across the touchpad from the two hooks on top of the part.
    • Be careful not to damage the black wire when removing from the two hooks.
  8. Acer Chromebook C740-C4PE Touchpad Replacement: 8 단계, 이미지 2개 중 1개 Acer Chromebook C740-C4PE Touchpad Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the flap on the wire connecting the motherboard and remove the connector.
  9. Acer Chromebook C740-C4PE Touchpad Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the touchpad from the device.
결론
작성자
1다른 기여자 명과 함께
Jacob Kahn
회원 가입일: 10/17/17
273 평판
안내서 2개를 작성함
UMass Dartmouth, Team S6-G4, Rockett Fall 2017 UMass Dartmouth, Team S6-G4, Rockett Fall 2017 회원
UMASSD-ROCKETT-F17S6G4
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 418
