주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-111-C670 Keyboard Key Replacement
필요한 것
  1. Acer Chromebook CB3-111-C670 Keyboard Key Replacement, Keyboard Key: 1 단계, 이미지 1/1
    • Remove broken key(s) using the flat end of spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular spudger and tweezer should be used whenever possible.
    • When reinstalling the key, no spudger is needed. Just pop it into place with fingers.
  2. Acer Chromebook CB3-111-C670 Keyboard Key Replacement: 2 단계, 이미지 1/2 Acer Chromebook CB3-111-C670 Keyboard Key Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using the flat end of the spudger, very carefully lift up the corners of the cradle.
    • With the help of tweezers (needle nose works best), pull the hooks of the cradle out.
    • For re-installation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Tony
회원 가입일: 01/20/16
459 평판
안내서 2개 작성하였습니다
USF Tampa, Team 10-5, Remmell Spring 2016 USF Tampa, Team 10-5, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G5
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
no help i need help putting it on with out that
Simon Kuhn - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 61
전체 시간: 7,392
