주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-111-C670 Screen Replacement
필요한 것
  1. Acer Chromebook CB3-111-C670 Screen Replacement, Screen: 1 단계, 이미지 1/2 Acer Chromebook CB3-111-C670 Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Unplug and power off the laptop before starting this repair.
    • Pry the white frame away from the screen with an opening tool.
    • As you move the spudger along the seam between the frame and the screen, the clips holding the frame in place will loosen.
  2. Acer Chromebook CB3-111-C670 Screen Replacement: 2 단계, 이미지 1/2 Acer Chromebook CB3-111-C670 Screen Replacement: 2 단계, 이미지 2/2
    • Remove the four screws within the silver brackets that are holding the screen to the back of the laptop.
  3. Acer Chromebook CB3-111-C670 Screen Replacement: 3 단계, 이미지 1/1
    • Once you've removed the screws, lift the piece of tape that is covering the display connector.
    • Use a spudger to flip up the black tab on top of the connector to unlock the ZIF connector.
  4. Acer Chromebook CB3-111-C670 Screen Replacement: 4 단계, 이미지 1/1
    • Pull the ribbon cable out with tweezers and remove the screen.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Allen Lewis
회원 가입일: 01/20/16
259 평판
안내서 1개 작성함
USF Tampa, Team 10-5, Remmell Spring 2016 USF Tampa, Team 10-5, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G5
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
Very easy. Thanks
johnqm123 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 4,973
