주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-111-C670 WLAN Chip Replacement
필요한 것
  1. Acer Chromebook CB3-111-C670 WLAN Chip Replacement, WLAN Chip: 1 단계, 이미지 1/1
    • Turn off your Chromebook and disconnect any charging cables.
    • Turn the Chromebook over so that the back panel with the Chromebook's serial number is facing upward.
    • Use the Phillips #000 screwdriver to remove the twelve screws from the back panel.
    • Use an opening tool to detach the back panel. Start at one of the four corners of the Chromebook and gently work around the edges. Insert it in the crease where the back panel and the main board meet. You should hear a slight click; this is the sound of the back panel detaching from the board.
    • Be careful not to apply too much force or you could damage the ribbon cable that connects the back panel to the motherboard.
    • Once you have detached the back panel, do not lift it vertically from the Chromebook. With the Chromebook facing in the direction as shown in the picture above, take the right hand side of the back panel and lift it toward the left, as if you are opening a book.
  2. Acer Chromebook CB3-111-C670 WLAN Chip Replacement: 2 단계, 이미지 1/3 Acer Chromebook CB3-111-C670 WLAN Chip Replacement: 2 단계, 이미지 2/3 Acer Chromebook CB3-111-C670 WLAN Chip Replacement: 2 단계, 이미지 3/3
    • Disconnect the coaxial cables from the WLAN board located near the top left corner of the motherboard.
    • Grasp the top and bottom edge of the WLAN board using your fingers and gently disconnect it from the motherboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
lott
회원 가입일: 01/20/16
323 평판
안내서 1개 작성함
USF Tampa, Team 10-5, Remmell Spring 2016 USF Tampa, Team 10-5, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 1,738
