이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the Chromebook over so that the back panel with the Chromebook's serial number is facing upward.
Use the Phillips #000 screwdriver to remove the twelve screws from the back panel.
Use an opening tool to detach the back panel. Start at one of the four corners of the Chromebook and gently work around the edges. Insert it in the crease where the back panel and the main board meet. You should hear a slight click; this is the sound of the back panel detaching from the board.
Disconnect the coaxial cables from the WLAN board located near the top left corner of the motherboard.
Grasp the top and bottom edge of the WLAN board using your fingers and gently disconnect it from the motherboard.
다른 4명이 해당 안내서를 완성하였습니다.
