주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-111-C8UB Back Panel Removal
필요한 것
  1. Acer Chromebook CB3-111-C8UB Back Panel Removal, Back Panel Removal: 1 단계, 이미지 1/2 Acer Chromebook CB3-111-C8UB Back Panel Removal, Back Panel Removal: 1 단계, 이미지 2/2
    • Position the laptop upside down with the hinges on the side furthest away from you.
    • Remove the eight 8mm screws with a phillips #1 screwdriver,
    • Remove the four 4.5mm screws with a phillips #1 screwdriver,
  2. Acer Chromebook CB3-111-C8UB Back Panel Removal: 2 단계, 이미지 1/3 Acer Chromebook CB3-111-C8UB Back Panel Removal: 2 단계, 이미지 2/3 Acer Chromebook CB3-111-C8UB Back Panel Removal: 2 단계, 이미지 3/3
    • There is a wire connecting the two pieces of the laptop, from the inside, on the left, be careful not to damage it.
    • Use the plastic opening tool to pry open then remove the plastic base from the rest of the laptop. Start from the right side and work towards the left.
    • Set the plastic base beside the laptop by opening it as if you were opening a book.
  3. Acer Chromebook CB3-111-C8UB Back Panel Removal: 3 단계, 이미지 1/2 Acer Chromebook CB3-111-C8UB Back Panel Removal: 3 단계, 이미지 2/2
    • Flip up the small white ZIF connector by using a fingernail or metal spudger.
    • Pull the blue tab to remove the ribbon cable.
    • The ribbon cable is adhered to the plastic so it will take a little bit of force to remove it.
결론
Travis Vo
회원 가입일: 01/27/17
426 평판
안내서 4개 작성하였습니다
Cal Poly, Team 22-7, Maness Winter 2017 Cal Poly, Team 22-7, Maness Winter 2017 회원
CPSU-MANESS-W17S22G7
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
When I removed the screws from the bottom (Step 1), the 8 screws closest to the hinge were 7mm, and the front 4 were 5mm. Hope this helps someone in the future.
lumberjackdavid - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 17
전체 시간: 1,628
