소개
This guide is for doing a battery replacement in the case that your battery is old and/or doesn't work anymore. The guide includes how to open up the back up the laptop in order to get to the battery. There is only a small tricky part in the final removal of the battery where you have to disconnect the connection of the battery on the logic board. Keep in mind that batteries can be hazardous if not handled carefully.
부품
지정된 부품이 없습니다.
Position the laptop upside down with the hinges on the side furthest away from you.
Remove the eight 8mm screws with a phillips #1 screwdriver,
Remove the four 4.5mm screws with a phillips #1 screwdriver,
Locate and remove the two 6mm screws holding the battery in place with a Phillips #1 screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
QUESTION - DO CHROMEBOOKS NEED A BATTERY TO WORK??? My Acer CB3-111-C8UB battery light—which is usually blue because I mostly use it electrically connected—occasionally turns orange, which I suppose means the battery is being recharged. My Windows 10 laptops function fully via their adapter and without any battery. I know, generally tablets have to have a working battery to operate—even via their adapter, but Chromebooks also need a functioning battery to work, even with the charger connected to the electric outlet? Thanks.
