주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-111-C8UB Battery Replacement
필요한 것
  1. Acer Chromebook CB3-111-C8UB Battery Replacement, Back Panel Removal: 1 단계, 이미지 2개 중 1개 Acer Chromebook CB3-111-C8UB Battery Replacement, Back Panel Removal: 1 단계, 이미지 2개 중 2개
    • Position the laptop upside down with the hinges on the side furthest away from you.
    • Remove the eight 8mm screws with a phillips #1 screwdriver,
    • Remove the four 4.5mm screws with a phillips #1 screwdriver,
  2. Acer Chromebook CB3-111-C8UB Battery Replacement: 2 단계, 이미지 3개 중 1개 Acer Chromebook CB3-111-C8UB Battery Replacement: 2 단계, 이미지 3개 중 2개 Acer Chromebook CB3-111-C8UB Battery Replacement: 2 단계, 이미지 3개 중 3개
    • There is a wire connecting the two pieces of the laptop, from the inside, on the left, be careful not to damage it.
    • Use the plastic opening tool to pry open then remove the plastic base from the rest of the laptop. Start from the right side and work towards the left.
    • Set the plastic base beside the laptop by opening it as if you were opening a book.
  3. Acer Chromebook CB3-111-C8UB Battery Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook CB3-111-C8UB Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Flip up the small white ZIF connector by using a fingernail or metal spudger.
    • Pull the blue tab to remove the ribbon cable.
    • The ribbon cable is adhered to the plastic so it will take a little bit of force to remove it.
  4. Acer Chromebook CB3-111-C8UB Battery Replacement, Battery: 4 단계, 이미지 1개 중 1개
    • Locate and remove the two 6mm screws holding the battery in place with a Phillips #1 screwdriver.
  5. Acer Chromebook CB3-111-C8UB Battery Replacement: 5 단계, 이미지 3개 중 1개 Acer Chromebook CB3-111-C8UB Battery Replacement: 5 단계, 이미지 3개 중 2개 Acer Chromebook CB3-111-C8UB Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the battery forward to clear the base from its clips.
    • Lift the battery up so that there is room to grab and unplug the bundled cable connector.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Travis Vo
회원 가입일: 01/27/17
426 평판
안내서 4개를 작성함
Cal Poly, Team 22-7, Maness Winter 2017 Cal Poly, Team 22-7, Maness Winter 2017 회원
CPSU-MANESS-W17S22G7
4 회원들
안내서 12개를 작성함
댓글 한 개
QUESTION - DO CHROMEBOOKS NEED A BATTERY TO WORK??? My Acer CB3-111-C8UB battery light—which is usually blue because I mostly use it electrically connected—occasionally turns orange, which I suppose means the battery is being recharged. My Windows 10 laptops function fully via their adapter and without any battery. I know, generally tablets have to have a working battery to operate—even via their adapter, but Chromebooks also need a functioning battery to work, even with the charger connected to the electric outlet? Thanks.
J. Laurence - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 19
지난 30일: 20
전체 시간: 1,106
