소개
You will be removing the plastic that borders the laptop's screen in order to access the screws and plug necessary to replace the screen. Be careful when you separate the screen from the laptop in the last step. Follow through the instructions so you can make sure you are not damaging your device.
This replacement is meant to be done if you are experiencing issues with your screen such as the ones outlined in this troubleshooting guide.
부품
지정된 부품이 없습니다.
Insert the plastic opening tool into the slit on the outer edge of the laptop's screen to remove the plastic piece that borders the screen. Work the plastic opening tool all the way around the screen until the plastic cover has been removed.
다른 한 분이 해당 안내서를 완성하였습니다.
