주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-111-C8UB Touchpad Replacement
필요한 것
  1. Acer Chromebook CB3-111-C8UB Touchpad Replacement, Back Panel Removal: 1 단계, 이미지 2개 중 1개 Acer Chromebook CB3-111-C8UB Touchpad Replacement, Back Panel Removal: 1 단계, 이미지 2개 중 2개
    • Position the laptop upside down with the hinges on the side furthest away from you.
    • Remove the eight 8mm screws with a phillips #1 screwdriver,
    • Remove the four 4.5mm screws with a phillips #1 screwdriver,
  2. Acer Chromebook CB3-111-C8UB Touchpad Replacement: 2 단계, 이미지 3개 중 1개 Acer Chromebook CB3-111-C8UB Touchpad Replacement: 2 단계, 이미지 3개 중 2개 Acer Chromebook CB3-111-C8UB Touchpad Replacement: 2 단계, 이미지 3개 중 3개
    • There is a wire connecting the two pieces of the laptop, from the inside, on the left, be careful not to damage it.
    • Use the plastic opening tool to pry open then remove the plastic base from the rest of the laptop. Start from the right side and work towards the left.
    • Set the plastic base beside the laptop by opening it as if you were opening a book.
  3. Acer Chromebook CB3-111-C8UB Touchpad Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook CB3-111-C8UB Touchpad Replacement: 3 단계, 이미지 2개 중 2개
    • Flip up the small white ZIF connector by using a fingernail or metal spudger.
    • Pull the blue tab to remove the ribbon cable.
    • The ribbon cable is adhered to the plastic so it will take a little bit of force to remove it.
  4. Acer Chromebook CB3-111-C8UB Touchpad Replacement, Battery: 4 단계, 이미지 1개 중 1개
    • Locate and remove the two 6mm screws holding the battery in place with a Phillips #1 screwdriver.
  5. Acer Chromebook CB3-111-C8UB Touchpad Replacement: 5 단계, 이미지 3개 중 1개 Acer Chromebook CB3-111-C8UB Touchpad Replacement: 5 단계, 이미지 3개 중 2개 Acer Chromebook CB3-111-C8UB Touchpad Replacement: 5 단계, 이미지 3개 중 3개
    • Pull the battery forward to clear the base from its clips.
    • Lift the battery up so that there is room to grab and unplug the bundled cable connector.
  6. Acer Chromebook CB3-111-C8UB Touchpad Replacement, Touchpad: 6 단계, 이미지 1개 중 1개
    • Use a metal spudger to flip up the white ZIF connector that holds the ribbon cable in place.
    • Unplug the black ribbon cable from the track pad assembly.
  7. Acer Chromebook CB3-111-C8UB Touchpad Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook CB3-111-C8UB Touchpad Replacement: 7 단계, 이미지 2개 중 2개
    • Use a Phillips #000 screwdriver to remove the three 2.4mm screws located across the top of the track pad assembly.
  8. Acer Chromebook CB3-111-C8UB Touchpad Replacement: 8 단계, 이미지 1개 중 1개
    • Use your finger to gently pull up on the assembly and slide a metal spudger under each of the two strips of tape and peel them off of the main metal plate.
  9. Acer Chromebook CB3-111-C8UB Touchpad Replacement: 9 단계, 이미지 1개 중 1개
    • Slide the track pad assembly up towards the motherboard until it can be lifted up and out.
결론
작성자
4다른 기여자 명과 함께
Travis Vo
회원 가입일: 01/27/17
426 평판
안내서 4개를 작성함
Cal Poly, Team 22-7, Maness Winter 2017 Cal Poly, Team 22-7, Maness Winter 2017 회원
CPSU-MANESS-W17S22G7
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 14
전체 시간: 1,217
