주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-131-C3KD Speakers Replacement
필요한 것
  1. Acer Chromebook CB3-131-C3KD Speakers Replacement, Battery: 1 단계, 이미지 2개 중 1개 Acer Chromebook CB3-131-C3KD Speakers Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Make sure you turn off the laptop before starting.
    • Unscrew and remove the (11) eleven 4mm J0 head screws on the underside of the laptop using the JIS #0 screwdriver.
  2. Acer Chromebook CB3-131-C3KD Speakers Replacement: 2 단계, 이미지 3개 중 1개 Acer Chromebook CB3-131-C3KD Speakers Replacement: 2 단계, 이미지 3개 중 2개 Acer Chromebook CB3-131-C3KD Speakers Replacement: 2 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to remove the back cover.
    • Be careful not to damage the ribbon cable connecting the back cover to the laptop.
  3. Acer Chromebook CB3-131-C3KD Speakers Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook CB3-131-C3KD Speakers Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew the (2) two 3mm J0 Phillips head screws that hold the battery in place.
  4. Acer Chromebook CB3-131-C3KD Speakers Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook CB3-131-C3KD Speakers Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the battery from the motherboard.
    • Carefully disconnect the cable parallel to the board, not at an angle. Otherwise, you could damage the port.
  5. Acer Chromebook CB3-131-C3KD Speakers Replacement: 5 단계, 이미지 2개 중 1개 Acer Chromebook CB3-131-C3KD Speakers Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully lift the battery from one side, and then lift it out of the laptop.
  6. Acer Chromebook CB3-131-C3KD Speakers Replacement, Speakers: 6 단계, 이미지 3개 중 1개 Acer Chromebook CB3-131-C3KD Speakers Replacement, Speakers: 6 단계, 이미지 3개 중 2개 Acer Chromebook CB3-131-C3KD Speakers Replacement, Speakers: 6 단계, 이미지 3개 중 3개
    • Disconnect the three ribbon cables from the motherboard.
  7. Acer Chromebook CB3-131-C3KD Speakers Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook CB3-131-C3KD Speakers Replacement: 7 단계, 이미지 2개 중 2개
    • Unplug the cable by putting both thumbs on each tab and unlocking the cable by pushing the tabs away.
  8. Acer Chromebook CB3-131-C3KD Speakers Replacement: 8 단계, 이미지 3개 중 1개 Acer Chromebook CB3-131-C3KD Speakers Replacement: 8 단계, 이미지 3개 중 2개 Acer Chromebook CB3-131-C3KD Speakers Replacement: 8 단계, 이미지 3개 중 3개
    • Remove speakers by placing index finger on top and thumb on bottom of the speakers.
    • Peel speakers away from the base that is connected by an adhesive.
  9. Acer Chromebook CB3-131-C3KD Speakers Replacement: 9 단계, 이미지 3개 중 1개 Acer Chromebook CB3-131-C3KD Speakers Replacement: 9 단계, 이미지 3개 중 2개 Acer Chromebook CB3-131-C3KD Speakers Replacement: 9 단계, 이미지 3개 중 3개
    • Peel the black cord connecting the two speakers together away from the Velcro located at the midpoint between the two speakers.
    • Remove speakers from laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Johnathan
회원 가입일: 09/26/17
216 평판
안내서 2개를 작성함
USF Tampa, Team S11-G1, Passmore Fall 2017 USF Tampa, Team S11-G1, Passmore Fall 2017 회원
USFT-PASSMORE-F17S11G1
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 360
