주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-431-C5EX Display Replacement
필요한 것
  1. Acer Chromebook CB3-431-C5EX Display Replacement, Display: 1 단계, 이미지 1/1
    • Make sure the work area is clean and free from dirt and debris.
    • Open the lid of the laptop.
    • Place the laptop so the screen is facing upwards and the outside of the laptop is flat against a table.
  2. Acer Chromebook CB3-431-C5EX Display Replacement: 2 단계, 이미지 1/2 Acer Chromebook CB3-431-C5EX Display Replacement: 2 단계, 이미지 2/2
    • Carefully insert an opening tool under the screen bezel and gently pry it away from the edge of the screen.
    • Slowly slide the opening tool around the bezel on all four sides to separate it from the screen.
    • Be careful to not damage any wires that are under the bezel, or crack the bezel itself.
  3. Acer Chromebook CB3-431-C5EX Display Replacement: 3 단계, 이미지 1/1
    • Remove the four 2.8 mm screws from the screen using a Phillips #0 screwdriver and place them to the side for use later.
    • Be careful to not touch the tape protecting the display circuit board.
  4. Acer Chromebook CB3-431-C5EX Display Replacement: 4 단계, 이미지 1/3 Acer Chromebook CB3-431-C5EX Display Replacement: 4 단계, 이미지 2/3 Acer Chromebook CB3-431-C5EX Display Replacement: 4 단계, 이미지 3/3
    • Gently lay the screen against the keyboard.
    • Carefully remove the adapter connecting the display to the motherboard.
  5. Acer Chromebook CB3-431-C5EX Display Replacement: 5 단계, 이미지 1/1
    • Once you have separated the screen from the motherboard, carefully remove the display from the laptop.
결론
To reassemble your device, follow these instructions using a replacement screen, in reverse order.
Ethan
회원 가입일: 09/20/21
121 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 299
