주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-431-C5EX Display Replacement
필요한 것
  1. Acer Chromebook CB3-431-C5EX Display Replacement, Display: 1 단계, 이미지 1개 중 1개
    • Make sure the work area is clean and free from dirt and debris.
    • Open the lid of the laptop.
    • Place the laptop so the screen is facing upwards and the outside of the laptop is flat against a table.
  2. Acer Chromebook CB3-431-C5EX Display Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook CB3-431-C5EX Display Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully insert an opening tool under the screen bezel and gently pry it away from the edge of the screen.
    • Slowly slide the opening tool around the bezel on all four sides to separate it from the screen.
    • Be careful to not damage any wires that are under the bezel, or crack the bezel itself.
  3. Acer Chromebook CB3-431-C5EX Display Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the four 2.8 mm screws from the screen using a Phillips #0 screwdriver and place them to the side for use later.
    • Be careful to not touch the tape protecting the display circuit board.
  4. Acer Chromebook CB3-431-C5EX Display Replacement: 4 단계, 이미지 3개 중 1개 Acer Chromebook CB3-431-C5EX Display Replacement: 4 단계, 이미지 3개 중 2개 Acer Chromebook CB3-431-C5EX Display Replacement: 4 단계, 이미지 3개 중 3개
    • Gently lay the screen against the keyboard.
    • Carefully remove the adapter connecting the display to the motherboard.
  5. Acer Chromebook CB3-431-C5EX Display Replacement: 5 단계, 이미지 1개 중 1개
    • Once you have separated the screen from the motherboard, carefully remove the display from the laptop.
결론
To reassemble your device, follow these instructions using a replacement screen, in reverse order.
작성자
3다른 기여자 명과 함께
Ethan
회원 가입일: 09/20/21
121 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 4
전체 시간: 327
