주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-431-C5EX Motherboard Replacement
필요한 것
  1. Acer Chromebook CB3-431-C5EX Motherboard Replacement, Bottom Panel: 1 단계, 이미지 1개 중 1개
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook CB3-431-C5EX Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Motherboard Replacement, Battery: 4 단계, 이미지 1개 중 1개
    • Remove the two 4mm Phillips #0 screws on either side of the battery pack that are securing it in place.
  5. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Acer Chromebook CB3-431-C5EX Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Disconnect the taped white 8-pin cable on the bottom right of the battery pack.
    • Use thumbnail to pull on the small protruding tabs on either side of the connector.
  6. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully lift the entire battery pack out of the laptop.
  7. Acer Chromebook CB3-431-C5EX Motherboard Replacement, Motherboard: 7 단계, 이미지 2개 중 1개 Acer Chromebook CB3-431-C5EX Motherboard Replacement, Motherboard: 7 단계, 이미지 2개 중 2개
    • Remove the 4.7 mm screw from the Wi-Fi card using a Phillips #0 screwdriver.
    • Remove the Wi-Fi card from the laptop.
  8. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Acer Chromebook CB3-431-C5EX Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Unplug the black wire connecting the small circuit board to the motherboard.
  9. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Acer Chromebook CB3-431-C5EX Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Acer Chromebook CB3-431-C5EX Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Lift the respective white and black tabs and slide the ribbon cables out of their connectors.
  10. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Acer Chromebook CB3-431-C5EX Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Carefully remove the display adapter from the motherboard.
  11. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Acer Chromebook CB3-431-C5EX Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the black tab connecting the motherboard to the keyboard.
  12. Acer Chromebook CB3-431-C5EX Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Acer Chromebook CB3-431-C5EX Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the five 4.7 mm screws from the motherboard using a Phillips #0 screwdriver.
    • Remove the two 4.5 mm screws from the motherboard using a Phillips #0 screwdriver.
    • Gently remove motherboard from the laptop.
결론
작성자
2다른 기여자 명과 함께
Graham Caldwell Blondes
회원 가입일: 09/20/21
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 25
전체 시간: 753
