주요 콘텐츠로 건너뛰기
Acer Chromebook CB3-431-C5EX Speaker Replacement
필요한 것
  1. Acer Chromebook CB3-431-C5EX Speaker Replacement, Bottom Panel: 1 단계, 이미지 1개 중 1개
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Speaker Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook CB3-431-C5EX Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Speaker Replacement, Internal Speakers: 4 단계, 이미지 1개 중 1개
    • Remove the two 4mm Phillips #0 screws securing the speaker.
  5. Acer Chromebook CB3-431-C5EX Speaker Replacement: 5 단계, 이미지 2개 중 1개 Acer Chromebook CB3-431-C5EX Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the speaker from the computer.
    • Repeat the previous steps to remove the second speaker from the computer.
    • Note that the two speakers are connected by a wire, so you must replace both of them.
  6. Acer Chromebook CB3-431-C5EX Speaker Replacement: 6 단계, 이미지 2개 중 1개 Acer Chromebook CB3-431-C5EX Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Disconnect the speaker wire from the circuit board by grabbing the plug by its plastic edges and gently pulling it straight out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Cayley Ho
회원 가입일: 04/18/17
548 평판
안내서 3개를 작성함
Cal Poly, Team S17-G3, Banghart Spring 2017 Cal Poly, Team S17-G3, Banghart Spring 2017 회원
CPSU-BANGHART-S17S17G3
5 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 19
전체 시간: 1,065
