주요 콘텐츠로 건너뛰기
Acer Chromebook CB315-3HT-C3FQ Speaker Replacement
필요한 것
  1. Acer Chromebook CB315-3HT-C3FQ Speaker Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Flip the Chromebook over so the bottom is facing up.
  2. Acer Chromebook CB315-3HT-C3FQ Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all 10 screws that hold the bottom panel in place using a Phillips #1 screwdriver.
  3. Acer Chromebook CB315-3HT-C3FQ Speaker Replacement: 3 단계, 이미지 2개 중 1개 Acer Chromebook CB315-3HT-C3FQ Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Use an iFixit opening tool to pry the bottom panel up and detach it from the rest of the Chromebook.
  4. Acer Chromebook CB315-3HT-C3FQ Speaker Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook CB315-3HT-C3FQ Speaker Replacement: 4 단계, 이미지 2개 중 2개
    • Always wear an anti-static wrist strap when working with an electronic device, as static electricity from your hand could damage it.
    • To use the anti-static strap, attach the strap to your wrist and then attach the end of the cord to something that is also metal, preferably something in your Chromebook. This strap will discharge any static electricity that you build up instead of it going into the metal parts of your computer, which could damage the components.
  5. Acer Chromebook CB315-3HT-C3FQ Speaker Replacement, Speaker: 5 단계, 이미지 3개 중 1개 Acer Chromebook CB315-3HT-C3FQ Speaker Replacement, Speaker: 5 단계, 이미지 3개 중 2개 Acer Chromebook CB315-3HT-C3FQ Speaker Replacement, Speaker: 5 단계, 이미지 3개 중 3개
    • Unplug the speaker cord from the motherboard's port.
    • Remove the speakers from the laptop.
    • Scan the QR code located in between the left and right speakers. The QR code will take you to different sites that sell the internal speakers that are for the Acer Chromebook 315.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kyle
회원 가입일: 03/20/24
327 평판
안내서 3개를 작성함
UMass Dartmouth, Team 1-5, Santin Spring 2024 UMass Dartmouth, Team 1-5, Santin Spring 2024 회원
UMASSD-SANTIN-S24S1G5
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 12
전체 시간: 172
