이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
First begin by flipping the laptop on its back and having the back cover face you directly.
Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
Using a plastic spudger, open the back cover and remove it from the laptop.
look for the battery in the bottom half of the computer
Once you have found the battery, look for the screws that secure the battery, in the upper left and right corners.
Begin by unscrewing the two Phillips head screws that hold down the battery using a J1 sized screwdriver.
Finally remove the battery from the laptop.
