주요 콘텐츠로 건너뛰기
Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board Replacement
필요한 것
  1. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: 1 단계, 이미지 1/2 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: 1 단계, 이미지 2/2
    • First begin by flipping the laptop on its back and having the back cover face you directly.
    • Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
  2. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 2 단계, 이미지 1/1
    • Using a plastic spudger, open the back cover and remove it from the laptop.
  3. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Secondary Circuit Board: 3 단계, 이미지 1/3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Secondary Circuit Board: 3 단계, 이미지 2/3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement, Secondary Circuit Board: 3 단계, 이미지 3/3
    • Identify the port that is connected to the speaker.
    • Using tweezers, separate the cable from the port.
  4. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 4 단계, 이미지 1/2 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 4 단계, 이미지 2/2
    • Find and remove the blue tape from the circuit board.
  5. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 5 단계, 이미지 1/3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 5 단계, 이미지 2/3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 5 단계, 이미지 3/3
    • Remove the black tape from the port.
  6. Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 6 단계, 이미지 1/3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 6 단계, 이미지 2/3 Acer Chromebook CB5-312T-K 8Z9 Secondary Circuit Board  Replacement: 6 단계, 이미지 3/3
    • Identify the two Phillips screws.
    • Remove the two screws holding down the board with a J1 Phillips screwdriver.
    • Gently lift the board from the Chromebook.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cole O'Neal
회원 가입일: 09/25/17
148 평판
안내서 1개 작성함
University of North Texas, Team S1-G4, Thompson Fall 2017 University of North Texas, Team S1-G4, Thompson Fall 2017 회원
UNT-THOMPSON-F17S1G4
4 회원들
안내서 10개 작성하였습니다
댓글 2개
Any ideas about where to purchase this part? I am almost certain that it is the problem with my sound. Also, I can get to it no problem, but I am struggling finding a replacement part.
littlemas2 - 답글
I have looked on numerous pages on google, both with the part number and with the Chromebook model number and have yet to be able to find a supplier.
littlemas2 -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 655
