주요 콘텐츠로 건너뛰기
Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement
필요한 것
  1. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: 1 단계, 이미지 1/2 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Acer Chromebook CB5-312T-K 8Z9 Back Cover: 1 단계, 이미지 2/2
    • First begin by flipping the laptop on its back and having the back cover face you directly.
    • Then unscrew the ten Phillips head screws that hold down the back cover using a Phillips #0 Screw Driver.
  2. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: 2 단계, 이미지 1/1
    • Using a plastic spudger, open the back cover and remove it from the laptop.
  3. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Battery: 3 단계, 이미지 1/3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Battery: 3 단계, 이미지 2/3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Battery: 3 단계, 이미지 3/3
    • look for the battery in the bottom half of the computer
    • Once you have found the battery, look for the screws that secure the battery, in the upper left and right corners.
  4. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: 4 단계, 이미지 1/3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: 4 단계, 이미지 2/3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: 4 단계, 이미지 3/3
    • Begin by unscrewing the two Phillips head screws that hold down the battery using a J1 sized screwdriver.
    • Finally remove the battery from the laptop.
  5. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Speaker: 5 단계, 이미지 1/3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Speaker: 5 단계, 이미지 2/3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement, Speaker: 5 단계, 이미지 3/3
    • Begin by locating the speakers.
    • Once you have found where the speakers are, direct your attention to the speaker to the left of the mouse pad.
    • Grab your tweezers and begin disconnecting the wire that connects the speakers to the circuit board on the upper left corner.
  6. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: 6 단계, 이미지 1/3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: 6 단계, 이미지 2/3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: 6 단계, 이미지 3/3
    • Locate where the mouse pad would be, this should be relatively easy as it will be right in between the two speakers.
    • Start peeling off the black tape that is covering the speaker wires.
    • Fold back the cables that are on top of the wires for easy removal of the speakers.
  7. Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: 7 단계, 이미지 1/3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: 7 단계, 이미지 2/3 Acer Chromebook CB5-312T-K 8Z9 Speaker Replacement: 7 단계, 이미지 3/3
    • Direct your attention back to the speaker that you were first working with in step 5.
    • Start by pulling up on the speaker, it should simply come right out.
    • Repeat this for the right speaker.
    • Once the two speakers are removed, unhook the wires from any clips that may be holding it to the computer.
결론
Kyle
회원 가입일: 09/25/17
125 평판
안내서 1개 작성함
University of North Texas, Team S1-G4, Thompson Fall 2017 University of North Texas, Team S1-G4, Thompson Fall 2017 회원
UNT-THOMPSON-F17S1G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 446
