주요 콘텐츠로 건너뛰기
Acer Chromebook CB5-571-C5XU Battery Replacement
필요한 것
  1. Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: 1 단계, 이미지 2개 중 1개 Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: 1 단계, 이미지 2개 중 2개
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Battery Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook CB5-571-C5XU Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Gently lift the battery out and remove it from the laptop casing.
결론
To reassemble your device, follow these guidelines in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kenneth Bowers
회원 가입일: 04/08/16
1,432 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 947
