주요 콘텐츠로 건너뛰기
Acer Chromebook CB5-571-C5XU Fan Replacement
필요한 것
  1. Acer Chromebook CB5-571-C5XU Fan Replacement, Bottom Case: 1 단계, 이미지 2개 중 1개 Acer Chromebook CB5-571-C5XU Fan Replacement, Bottom Case: 1 단계, 이미지 2개 중 2개
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Fan Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook CB5-571-C5XU Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Fan Replacement, Fan: 3 단계, 이미지 2개 중 1개 Acer Chromebook CB5-571-C5XU Fan Replacement, Fan: 3 단계, 이미지 2개 중 2개
    • Using a Phillips #0 screwdriver, unscrew the screw to the right of the fan.
    • Remember to have a small container to place the screw in, so it does not get lost.
  4. Acer Chromebook CB5-571-C5XU Fan Replacement: 4 단계, 이미지 2개 중 1개 Acer Chromebook CB5-571-C5XU Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Using the Phillips #0 screwdriver, unscrew the four screws connecting the heatsink to the motherboard.
    • Remember to have a safe place to place the screws, so none of them get lost.
  5. Acer Chromebook CB5-571-C5XU Fan Replacement: 5 단계, 이미지 3개 중 1개 Acer Chromebook CB5-571-C5XU Fan Replacement: 5 단계, 이미지 3개 중 2개 Acer Chromebook CB5-571-C5XU Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully unhook the black and white wires from the circumference of the fan.
    • It might help to use the pointed end of the spudger tool to unhook the wires.
    • Do not tug too hard on the wires, as they can easily disconnect and snap off from the motherboard.
  6. Acer Chromebook CB5-571-C5XU Fan Replacement: 6 단계, 이미지 2개 중 1개 Acer Chromebook CB5-571-C5XU Fan Replacement: 6 단계, 이미지 2개 중 2개
    • Using the spudger tool, carefully remove the wires connecting the fan to the motherboard.
  7. Acer Chromebook CB5-571-C5XU Fan Replacement: 7 단계, 이미지 2개 중 1개 Acer Chromebook CB5-571-C5XU Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Using the flat side of the spudger, firmly pry the fan off of the components, as well as the heatsink from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Erin Moffatt
회원 가입일: 10/17/17
282 평판
안내서 2개를 작성함
UMass Dartmouth, Team S6-G1, Rockett Fall 2017 UMass Dartmouth, Team S6-G1, Rockett Fall 2017 회원
UMASSD-ROCKETT-F17S6G1
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 17
지난 30일: 22
전체 시간: 327
