소개
Chromebooks traditionally have very small Solid State Drives (SSD) because most data is stored in the cloud. This particular model has a 32 GB SSD. However, if you have the need for a larger-capacity SSD, this guide will show you how to replace it.
필요한 것
Using the Phillips #0 Screwdriver, unscrew the single screw holding the Solid State Drive in place.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
