주요 콘텐츠로 건너뛰기
Acer Chromebook CB5-571-C5XU Trackpad Replacement
필요한 것
  1. Acer Chromebook CB5-571-C5XU Trackpad Replacement, Bottom Case: 1 단계, 이미지 2개 중 1개 Acer Chromebook CB5-571-C5XU Trackpad Replacement, Bottom Case: 1 단계, 이미지 2개 중 2개
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Trackpad Replacement: 2 단계, 이미지 2개 중 1개 Acer Chromebook CB5-571-C5XU Trackpad Replacement: 2 단계, 이미지 2개 중 2개
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Trackpad Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Trackpad Replacement: 4 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Trackpad Replacement: 5 단계, 이미지 1개 중 1개
    • Gently lift the battery out and remove it from the laptop casing.
  6. Acer Chromebook CB5-571-C5XU Trackpad Replacement, Trackpad: 6 단계, 이미지 1개 중 1개
    • Unhook the black ribbon from the motherboard, using the opening tool to pull the hooks in the direction of the arrows.
    • Once the hooks are released, simply pull the black ribbon outward to remove it from the motherboard.
  7. Acer Chromebook CB5-571-C5XU Trackpad Replacement: 7 단계, 이미지 3개 중 1개 Acer Chromebook CB5-571-C5XU Trackpad Replacement: 7 단계, 이미지 3개 중 2개 Acer Chromebook CB5-571-C5XU Trackpad Replacement: 7 단계, 이미지 3개 중 3개
    • Using a Phillips #0 screwdriver, remove the 7 screws holding the trackpad in place.
    • The metal piece at the bottom edge of the laptop will lift off after the screws are removed.
  8. Acer Chromebook CB5-571-C5XU Trackpad Replacement: 8 단계, 이미지 1개 중 1개
    • Use the spudger tool to unhook the locks on both sides of the end of the white ribbon. Pull the ribbon outward away from the motherboard.
  9. Acer Chromebook CB5-571-C5XU Trackpad Replacement: 9 단계, 이미지 2개 중 1개 Acer Chromebook CB5-571-C5XU Trackpad Replacement: 9 단계, 이미지 2개 중 2개
    • Use the spudger tool to pry the trackpad up and away from the laptop.
결론
작성자
5다른 기여자 명과 함께
David Flint
회원 가입일: 10/17/17
273 평판
안내서 2개를 작성함
UMass Dartmouth, Team S6-G1, Rockett Fall 2017 UMass Dartmouth, Team S6-G1, Rockett Fall 2017 회원
UMASSD-ROCKETT-F17S6G1
3 회원들
안내서 10개를 작성함
2가이드 댓글
How do I remove the touchpad from the backing/bracket? The replacement touchpad I bought has none of the metal bracket, and I believe I need to remove it from my old broken one.
Shawn H - 답글
For the record I ended up having to purchase a new mounting bracket separately and affix it ($5). Hope this helps someone. I’ve done the repair but the trackpad is still not functioning. Not sure what the issue is but the swap was pretty easy.
Shawn H - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 448
