주요 콘텐츠로 건너뛰기
Acer Chromebook CP5-471-C0EX Fan Replacement
필요한 것
  1. Acer Chromebook CP5-471-C0EX Fan Replacement, Back Cover: 1 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Fan Replacement, Back Cover: 1 단계, 이미지 2/2
    • Turn off the laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer Chromebook CP5-471-C0EX Fan Replacement: 2 단계, 이미지 1/3 Acer Chromebook CP5-471-C0EX Fan Replacement: 2 단계, 이미지 2/3 Acer Chromebook CP5-471-C0EX Fan Replacement: 2 단계, 이미지 3/3
    • Remove twelve 7 mm screws from the back of the laptop using a Phillips #1 screwdriver.
  3. Acer Chromebook CP5-471-C0EX Fan Replacement: 3 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Fan Replacement: 3 단계, 이미지 2/2
    • Use a Jimmy to pry apart the bottom of the case from the laptop.
    • Be careful not to warp or crack the case.
  4. Acer Chromebook CP5-471-C0EX Fan Replacement, Battery: 4 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Fan Replacement, Battery: 4 단계, 이미지 2/2
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  5. Acer Chromebook CP5-471-C0EX Fan Replacement: 5 단계, 이미지 1/1
    • Use your hands to lift the battery out of the device.
  6. Acer Chromebook CP5-471-C0EX Fan Replacement, Fan: 6 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Fan Replacement, Fan: 6 단계, 이미지 2/2
    • Gently pull the black and white cables up to disconnect them from the Wi-Fi card.
  7. Acer Chromebook CP5-471-C0EX Fan Replacement: 7 단계, 이미지 1/3 Acer Chromebook CP5-471-C0EX Fan Replacement: 7 단계, 이미지 2/3 Acer Chromebook CP5-471-C0EX Fan Replacement: 7 단계, 이미지 3/3
    • Unwind the Wi-Fi card wires from the side of the fan.
    • The wires need to be pulled down and around the first hook, as seen in image two.
    • Pull the black and white cables under the second hook and away from the fan.
  8. Acer Chromebook CP5-471-C0EX Fan Replacement: 8 단계, 이미지 1/3 Acer Chromebook CP5-471-C0EX Fan Replacement: 8 단계, 이미지 2/3 Acer Chromebook CP5-471-C0EX Fan Replacement: 8 단계, 이미지 3/3
    • Pull wires so they are out the way.
    • Loosen the six screws from the fan and heat sink.
    • The two screws closest to the fan cannot be removed from the fan, but will still loosen from the case.
  9. Acer Chromebook CP5-471-C0EX Fan Replacement: 9 단계, 이미지 1/3 Acer Chromebook CP5-471-C0EX Fan Replacement: 9 단계, 이미지 2/3 Acer Chromebook CP5-471-C0EX Fan Replacement: 9 단계, 이미지 3/3
    • Gently lift the fan out of the case, but do not remove it fully; there is still one more cable attached.
    • Pull the cable out of its socket on the motherboard.
    • Remove the fan from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Cody Venne
회원 가입일: 02/08/22
133 평판
안내서 1개 작성함
Gateway, Team 1-1, Saknee Spring 2022 Gateway, Team 1-1, Saknee Spring 2022 회원
GCC-SAKNEE-S22S1G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 99
