주요 콘텐츠로 건너뛰기
Acer Chromebook CP5-471-C0EX Motherboard Replacement
필요한 것
  1. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  2. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 2 단계, 이미지 1/1
    • Use your hands to lift the battery out of the device.
  3. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Trackpad: 3 단계, 이미지 1/3 Acer Chromebook CP5-471-C0EX Motherboard Replacement, Trackpad: 3 단계, 이미지 2/3 Acer Chromebook CP5-471-C0EX Motherboard Replacement, Trackpad: 3 단계, 이미지 3/3
    • Disconnect the wide black ribbon cable from the motherboard using an iFixit opening tool.
    • Disconnect the blue-tipped ribbon from the motherboard.
    • Be careful not to damage the motherboard while removing the ribbon cables.
  4. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 4 단계, 이미지 1/3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 4 단계, 이미지 2/3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 4 단계, 이미지 3/3
    • Remove the golden tape connecting the trackpad to the plastic divider using an iFixit opening tool.
    • Peel back the black plastic divider that separates the motherboard and trackpad.
  5. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 5 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove four 3 mm screws from the trackpad using a Phillips #1 screwdriver.
  6. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 6 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 6 단계, 이미지 2/2
    • Carefully remove the trackpad from the device.
  7. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Wi-Fi Card: 7 단계, 이미지 1/1
    • Gently pull the black and white cables up to disconnect them from the Wi-Fi card.
  8. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 8 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the single 3 mm screw using a Phillips #1 screwdriver.
  9. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 9 단계, 이미지 1/1
    • Gently pull the wireless card away from the motherboard to remove it.
  10. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Fan: 10 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Motherboard Replacement, Fan: 10 단계, 이미지 2/2
  11. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 11 단계, 이미지 1/3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 11 단계, 이미지 2/3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 11 단계, 이미지 3/3
    • Unwind the Wi-Fi card wires from the side of the fan.
    • The wires need to be pulled down and around the first hook, as seen in image two.
    • Pull the black and white cables under the second hook and away from the fan.
  12. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 12 단계, 이미지 1/3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 12 단계, 이미지 2/3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 12 단계, 이미지 3/3
    • Pull wires so they are out the way.
    • Loosen the six screws from the fan and heat sink.
    • The two screws closest to the fan cannot be removed from the fan, but will still loosen from the case.
  13. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 13 단계, 이미지 1/3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 13 단계, 이미지 2/3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 13 단계, 이미지 3/3
    • Gently lift the fan out of the case, but do not remove it fully; there is still one more cable attached.
    • Pull the cable out of its socket on the motherboard.
    • Remove the fan from the laptop.
  14. Acer Chromebook CP5-471-C0EX Motherboard Replacement, Motherboard: 14 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Motherboard Replacement, Motherboard: 14 단계, 이미지 2/2
    • Push on the sides of the connector to gently disconnect the speaker cable from the motherboard.
  15. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 15 단계, 이미지 1/3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 15 단계, 이미지 2/3 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 15 단계, 이미지 3/3
    • Use an iFixit opening tool to pry the display cable up from the motherboard.
  16. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 16 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Motherboard Replacement: 16 단계, 이미지 2/2
    • Remove seven 3 mm screws from the motherboard using a Phillips #1 screwdriver.
  17. Acer Chromebook CP5-471-C0EX Motherboard Replacement: 17 단계, 이미지 1/1
    • Remove the motherboard from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Naomi Salas
회원 가입일: 04/05/22
244 평판
안내서 2개 작성하였습니다
Gateway, Team 1-1, Saknee Spring 2022 Gateway, Team 1-1, Saknee Spring 2022 회원
GCC-SAKNEE-S22S1G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 14
전체 시간: 286
