주요 콘텐츠로 건너뛰기
Acer Chromebook CP5-471-C0EX Trackpad Replacement
필요한 것
  1. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Back Cover: 1 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Back Cover: 1 단계, 이미지 2/2
    • Turn off the laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer Chromebook CP5-471-C0EX Trackpad Replacement: 2 단계, 이미지 1/3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: 2 단계, 이미지 2/3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: 2 단계, 이미지 3/3
    • Remove twelve 7 mm screws from the back of the laptop using a Phillips #1 screwdriver.
  3. Acer Chromebook CP5-471-C0EX Trackpad Replacement: 3 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Trackpad Replacement: 3 단계, 이미지 2/2
    • Use a Jimmy to pry apart the bottom of the case from the laptop.
    • Be careful not to warp or crack the case.
  4. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Battery: 4 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Battery: 4 단계, 이미지 2/2
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  5. Acer Chromebook CP5-471-C0EX Trackpad Replacement: 5 단계, 이미지 1/1
    • Use your hands to lift the battery out of the device.
  6. Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: 6 단계, 이미지 1/3 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: 6 단계, 이미지 2/3 Acer Chromebook CP5-471-C0EX Trackpad Replacement, Trackpad: 6 단계, 이미지 3/3
    • Disconnect the wide black ribbon cable from the motherboard using an iFixit opening tool.
    • Disconnect the blue-tipped ribbon from the motherboard.
    • Be careful not to damage the motherboard while removing the ribbon cables.
  7. Acer Chromebook CP5-471-C0EX Trackpad Replacement: 7 단계, 이미지 1/3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: 7 단계, 이미지 2/3 Acer Chromebook CP5-471-C0EX Trackpad Replacement: 7 단계, 이미지 3/3
    • Remove the golden tape connecting the trackpad to the plastic divider using an iFixit opening tool.
    • Peel back the black plastic divider that separates the motherboard and trackpad.
  8. Acer Chromebook CP5-471-C0EX Trackpad Replacement: 8 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Trackpad Replacement: 8 단계, 이미지 2/2
    • Remove four 3 mm screws from the trackpad using a Phillips #1 screwdriver.
  9. Acer Chromebook CP5-471-C0EX Trackpad Replacement: 9 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Trackpad Replacement: 9 단계, 이미지 2/2
    • Carefully remove the trackpad from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Trestin Bachtiger
회원 가입일: 02/08/22
239 평판
안내서 1개 작성함
Gateway, Team 1-1, Saknee Spring 2022 Gateway, Team 1-1, Saknee Spring 2022 회원
GCC-SAKNEE-S22S1G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 105
