주요 콘텐츠로 건너뛰기
Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement
필요한 것
  1. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Back Cover: 1 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Back Cover: 1 단계, 이미지 2/2
    • Turn off the laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: 2 단계, 이미지 1/3 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: 2 단계, 이미지 2/3 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: 2 단계, 이미지 3/3
    • Remove twelve 7 mm screws from the back of the laptop using a Phillips #1 screwdriver.
  3. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: 3 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: 3 단계, 이미지 2/2
    • Use a Jimmy to pry apart the bottom of the case from the laptop.
    • Be careful not to warp or crack the case.
  4. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Battery: 4 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Battery: 4 단계, 이미지 2/2
    • Carefully detach the ribbon cable connecting the battery and the motherboard.
  5. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: 5 단계, 이미지 1/1
    • Use your hands to lift the battery out of the device.
  6. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement, Wi-Fi Card: 6 단계, 이미지 1/1
    • Gently pull the black and white cables up to disconnect them from the Wi-Fi card.
  7. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: 7 단계, 이미지 1/2 Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: 7 단계, 이미지 2/2
    • Remove the single 3 mm screw using a Phillips #1 screwdriver.
  8. Acer Chromebook CP5-471-C0EX Wi-Fi Card Replacement: 8 단계, 이미지 1/1
    • Gently pull the wireless card away from the motherboard to remove it.
결론
Aida mohamed
회원 가입일: 02/08/22
186 평판
안내서 1개 작성함
Gateway, Team 1-1, Saknee Spring 2022 Gateway, Team 1-1, Saknee Spring 2022 회원
GCC-SAKNEE-S22S1G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 134
