주요 콘텐츠로 건너뛰기
Acer Chromebook R11 Battery Replacement
필요한 것
  1. Acer Chromebook R11 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • The back cover of the R11 is held into place using 11 screws.
    • To remove, use a screwdriver appropriate for a JIS 1 screw.
  2. Acer Chromebook R11 Battery Replacement: 2 단계, 이미지 1/1
    • Battery is located in the bottom half of the computer.
    • Unscrew the two screws holding the battery in place. There is one on each side of the battery.
  3. Acer Chromebook R11 Battery Replacement: 3 단계, 이미지 1/1
    • Slide out the ribbon that is connecting the battery to the motherboard.
    • There are 7 wires leading to it, and each is a different color of the rainbow.
    • Disconnect the keyboard ribbon located at bottom center of motherboard.
  4. Acer Chromebook R11 Battery Replacement: 4 단계, 이미지 1/1
    • Remove the battery by pulling upwards.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Jermaine Hannans
회원 가입일: 02/16/17
386 평판
안내서 1개 작성함
USF Tampa, Team 1-2, Kass Spring 2017 USF Tampa, Team 1-2, Kass Spring 2017 회원
USFT-KASS-S17S1G2
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Hi. Incidentally while you have it apart check for heating of the chip that controls the USB3 port: this is known to be a weak point. As with many low end laptops they can’t run external devices like hard drives properly so may report incorrectly that they need formatting. Fix is to use external power device.
Andre De Guerin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 16
30일 전: 62
전체 시간: 9,481
