소개
Having battery issues? Here's how to replace it!
To avoid generating static between you and the device, you should wear a rubber bracelet. Not doing so could potentially damage your device.
필요한 것
The back cover of the R11 is held into place using 11 screws.
To remove, use a screwdriver appropriate for a JIS 1 screw.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 한 개
Hi. Incidentally while you have it apart check for heating of the chip that controls the USB3 port: this is known to be a weak point. As with many low end laptops they can’t run external devices like hard drives properly so may report incorrectly that they need formatting. Fix is to use external power device.
